pulses per mile fault
Old Jul 3, 2007 | 07:12 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
ok I just got my car started (95 LT1 in a 87 firebird) since I had it bored to a 12.5:1 compression 383. I also sent my computer out to PCMforless to get reconfiguered for the compression and added cubic inches. Now I am seeing code 97 4K pulses per mile fault? I have replaced the VSS sensor and still the code shows up. Other then the added engine changes I put in a different ignition box, Malory hifire to control the nitrous and rebuilt the tranny. Is the ignition causing this code? Is it in the computer? tranny? I have races this saterday what could happen if I run with this code?
Any Ideas?
code reads on computer: 97 4K pulses per mile fault (QDM)
95 LT1 and 4l60e
in a 87 firebird
95 LT1 and 4l60e
in a 87 firebird
Last edited by drperformance; Jul 3, 2007 at 07:17 PM. Reason: Automerged Doublepost
Old Jul 3, 2007 | 07:18 PM
Car: 1987 firebird
Transmission: 4l60e
Re: pulses per mile fault
95 LT1 and 4l60e
in a 87 firebird
Old Jul 3, 2007 | 09:38 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Does the speedometer show anything? Does it show correctly? What sensor did you replace the VSS with? The 3rdgen or 4thgen sensor?
If you run with a speedometer code, it won't hurt anything. Except, your tranny might not lock up the TCC in O/D.
Lou
Old Jul 3, 2007 | 11:34 PM
Car: 1987 firebird
Transmission: 4l60e
The speedo has never been hooked up in this car. I bought the cable -x to convert from an electronic to a mechanical speedo I just never hooded it up yet. But last year I never had this code and the speedo was the same way, unhooked.
As for the sensor I replaced it with it looks the same as the 95 4l60e sensor.
I also checked the reference voltage going to the vss and it is 5 volts, right where it should be.
Any ideas?
Toolsin
Feb 2, 2016 06:55 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
GouldyGTR
Sep 7, 2015 09:05 PM
