windshield wiper problem
Old Jul 21, 2007 | 08:10 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
my windshield wiper only has one speed, even when switching between low and high it stays constant. and on the delay range before low and high i get no movement. like its off
any suggestions?
this is how i bought the car so any ideas where to start looking would be appreciated
this is for a 1986 trans am
Old Jul 22, 2007 | 02:51 PM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: windshield wiper problem
so no one has any suggestions?
Old Jul 23, 2007 | 01:52 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
check the wiring around the motor, someone had mine wired up like that directly from the switch to the wiper motor.
Old Jul 23, 2007 | 02:39 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
it sounds like the delay board on thw wiper motor. they act much like the blower motor resistor. then again it's not uncommon for the switch to go bad on a gm. also have you looked into it at all? have you changed anything?
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
greenyone
Sep 2, 2015 03:39 PM
eddie jr
Aug 25, 2015 06:52 PM
