New car means new electrical issues...
Old Jul 28, 2007 | 04:34 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Ok guys I just picked my new 92 Z28, and there and some goofy things with the electronics. The power mirrors and interior light worked just fine, but then during the drive home they quit working. And the other issue is that the fog lights don't work. I've never done much with electronics besides a sound system, so I just need a starting point. Much help would be appreciated. Thanks!
Old Jul 29, 2007 | 06:35 PM
oifish's Avatar
Engine: 5.7 TPI L98
Re: New car means new electrical issues...
I was messing around with the fuses and I saw that the ACC fuse was blown. So I replaced it, but in a couple hours it blew again. What could be the source of this?
Old Jul 30, 2007 | 09:34 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
a short in the circuit after the fuse. such as the wiring or one of the componets connected to the circuit.
Old Jul 31, 2007 | 08:50 AM
oifish's Avatar
Engine: 5.7 TPI L98
It looks like the culprit is most likely the cigarette lighter. I did some searching and other people have said that usually if the fuse doesn't blow immediately then a drain on the lighter is usually the cause. I'll let you all know what I find when I get home from work.
Old Jul 31, 2007 | 11:25 AM
atomicskr's Avatar
Definitely check the cigarette lighter. I had a '91 'bird with the exact same problem.
RazorN8
Jan 7, 2022 11:44 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Exxon Limited
Aug 9, 2015 08:13 PM
