VATS BYPASS/ CRANK BUT NO FUEL
Old Aug 4, 2007 | 03:38 PM
marks91305's Avatar
So I wish I would have came on here a week sooner then I did, That would have saved me from buying a new battery and almost a new starter and solonoid. Now I realize what is going on, but not completely.
I pressed the VATS Module Relay together and now I can get crank. But no fuel. I checked the Orange wire to make sure there was power and then when i crank, the green/white wire get power to the tan wire. So now I am completely stuck.I am getting no fuel at all and I need to know where to bypass the other relay so I can get my car back home and not stuck in the street at my girlfriends house. I realize just about everyone has had this problem, I am new to the Third Gen scene, just came from the 280Z scene. Any help would be much appreciated.
Mark
Old Aug 5, 2007 | 08:00 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: VATS BYPASS/ CRANK BUT NO FUEL
there isn't any other relays for VATS other than the starter relay.
the fuel is disabled by the ECM if it doesn't receive the right signal from the VATS module.
these 2 articles should get you going.
https://www.thirdgen.org/vats
https://www.thirdgen.org/vats_passkey_system
Glowsock
Jul 24, 2025 03:15 PM
Jae992
Aug 27, 2015 09:07 AM
Winchester1094
Aug 18, 2015 10:23 AM
djmarch
Aug 9, 2015 05:27 PM
