REAL HID CONVERSION
Old Aug 5, 2007 | 11:12 PM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
REAL HID CONVERSION
i have the fortune of having a girlfriend whose dad works at a body shop. In our most recent build, (1989 IROC Z 5-SPEED CONVERTIBLE) we are planning to install real HID headlights from a BMW/MERCEDES from kits he has collected from crashed cars. i have the bulbs, headlight computer and bought aftermarket headlights in which i couls insert the bulb into. My question is will i fry any wires? the comp is 12v and bulbs are 35W and theyre real bright. please any info would help.
Old Aug 7, 2007 | 09:32 PM
wicho's Avatar
Car: CAMARO IROC-Z
Engine: 350 T.P.I
Re: REAL HID CONVERSION
i got some ultra white lights on my 89 camaro coupe is that what your talking about i bought the case and i bought the bulbs sep.
Old Aug 8, 2007 | 01:24 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
He's asking about wire size for true HIDs, not halogens.
You should be fine with the stock wiring, as the HID's will draw less power than your stock headlights. Or, look at the wire size on the HID power supplies you'll be installing and use wire to match it (if it's larger than stock).
Old Aug 8, 2007 | 06:42 PM
Jza's Avatar
Jza
Most likely no.. BUT the ballasts (what you're apparently calling the "comp") do draw a good bit of current on startup. I don't think the spike is enough to do any damage anywhere. Without knowing all the specifics of your vehicle, I'd say you're probably fine. As kev said, the original vehicle's wire gauge will give you a hint if your wire gauge is what's concerning you.
Old Aug 8, 2007 | 07:29 PM
2badcams's Avatar
thanks for help guys! yeah i found out they're called ballasts, and my gf's dad has tons of them from wrecked cars at his shop. (they mostly work on bmw's mercedes's & lexus. i didnt think their would be a problem either since the ballasts is 12V and bulbs only 35W. let me tell you though, what a differance from halogen! thanks!
Old Aug 12, 2007 | 05:07 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Got any pics?
Old Aug 12, 2007 | 05:37 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Yeah, I changed over to HIDs, your gonna love it
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mattcanty
Oct 12, 2015 11:08 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
