need quick help....metal clip in column
Old Aug 9, 2007 | 08:15 PM
Synful's Avatar
I tore down my column to install a new windshield wiper control arm/switch
(some idiot put a column from a different car into it and used a pulse/delay switch and the car is not equipped with a pulse/delay motor.....chaos ensued with the control arm functions)
well i got everything under control (except the damn wiring is driving me crazy fishing it back down through the column)
there is this V-shaped metal clip with a hook on one end of the V, popped out from somewhere around where the tumbler mechanism inserts. I didn't see how it popped out and can't figure out which way it goes back in, or what it even does.
any help would be appreciated.
Old Aug 9, 2007 | 08:25 PM
dustpusher's Avatar
Car: 88 IROC-Z
Re: need quick help....metal clip in column
There is a square hole near the tumbler.You should also have a white with two steel things on it.The steel sticks up.Put the other under the white peice and put both in the hole.I just took my column apart.I found a exploded pic of the column but cant rember the thread.
Old Aug 9, 2007 | 08:34 PM
Synful's Avatar
i don't have a "white with two steel things on it" just the metal v-shaped clip
Old Aug 10, 2007 | 10:44 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
A picture might be helpful. The steering column details in the service manuals are not very good. They have exploded views with a couple of 100 parts, so they are small and not very detailed. GM need to fit them on one 8.5 by 11 sheet.
The columns also have differnet parts and assemblies depending on if they are Tilt or non Tilt columns, so that information might also be helpful.
You can find some details on a tilt colum in this thread...
https://www.thirdgen.org/forums/elec...correctly.html
I am not sure if this is the one dustpucher was refering to.
Dave
Old Aug 10, 2007 | 11:09 PM
dustpusher's Avatar
Car: 88 IROC-Z
Thats the one.It is for the buzzer when keys are in ignition when off.
F-body-fan
Jan 12, 2023 01:49 PM
RS Reaper
Oct 17, 2018 07:52 PM
Night rider327
Feb 25, 2016 09:50 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
