Wiring
Old Aug 11, 2007 | 09:21 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Wiring
I'm not electically savy by any means so if some one can help please do. I'm installing an aftermarket ECU and the for the fan and fuel pump the harness comes equipped with a dedicated relay and a fuse and a wire marked positive(+) for each. So am I to just hook the positive wire to the fan/fuel pump ( should I put a ground wire too) and be done with it. Or is there more to it. Also with a 12V+ switch wire (needs 12V when the key is in the on and run position) what would/where be the best way to hook it up.
Old Aug 12, 2007 | 03:53 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Re: Wiring
You will most likely need to run a ground as well to make everything work. The ECU only care abouts what's on the positive side though so that's why that's all you got but you will need grounds.
For switched power, you can get under the drivers side panels and find one from the ignition switch harness (on top of the steering column). However, the easiest place would probably be from the factory radio harness. There's also a switched power wire there. It should be the yellow wire. You can just use a test light to test it with the key in run and if it lights up then test it with the key off and make sure it doesn't light up.
Old Aug 12, 2007 | 08:19 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Wiring
I wouldn't tap into the radio wire harness. Especially if you have 2 or 3 items that need a power source and it would be too much of an excessive draw on the radio wire which I believe is only an 16 or 18 gauge wire.. I would be more likely to say that it would be safer to put a spade blade on + wires and plug into the ACC fuse block..
I believe there are 2 spots in the fuse block for ACC to be plugged in. Just a suggestion.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
