need help with dash wiring to engine wiring plug.
Old Aug 12, 2007 | 12:31 PM
Brisco's Avatar
Hello. Do any of you know where I can get the pin outs for the engine to under dash wiring harness under the passenger side of the dash. I already have the pin outs for the ecm and have all that worked out but It is the harness that would connect the computer and the engine wiring harness to the underdash wiring harness. Please help me out if you have any information. I am stumped right now.
Old Aug 12, 2007 | 09:45 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: need help with dash wiring to engine wiring plug.
Do you mean the connector C207?
If so, you can check this wiring diagram page (search for C207) and find the pinout for your year.
http://www.austinthirdgen.org/index.php?pid=19
Hope this helps.
Lou
Old Aug 12, 2007 | 10:51 PM
Brisco's Avatar
is C207 the main plug that connects the engine harness to the dash harness under the passenger side that vats goes through?
Old Aug 12, 2007 | 11:12 PM
Brisco's Avatar
OK. It is great that I have found the name and some pin outs for this c207 for an 89 camaro. What I am also looking for is where these go? if any go ti ign+ ot ground and what is needed to power the ecm properly and what is needed to power the engine sensors properly. I am getting a lot of coded with my swap and none of the engine sensors are reading on the snapon scan tool. Is there anything on this plug crutial for proper operation. I hafe the pas key module wired up and working but I think I still have some wires not hooked up. If someone could add where each one goes that would be nice.
Jorlain
Aug 24, 2022 05:11 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 13, 2015 12:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
