Car dies ALOT while driving
Old Aug 13, 2007 | 05:00 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
Ok i have an 88 gta with a 350 tpi. The car just keeps dying each time i hit a bump or one day it just died when i punched the steering colmn. lately its been dying around turns too. The car used to not start up agian because of the VATS system. id have to wait a while before it would restart. but then i overrided the vats system by doing the resistor trick, the car still dies but im able to restart it instantly. Somtimes i go a week with out it dying or other times it will die as many times as i turn in a day. Im not sure if this is the lock cylender or the Vats module... or a loose wire elsewere. hoping some one would help me out Ive decided not to drive it untill it gets fixed due to safty reasons and im getting with drawls .
Old Aug 14, 2007 | 02:28 PM
Engine: 350 tpi
Re: Car dies ALOT while driving
hmmm any ideas? should i replace the ignition cylender? and see if that does it?
Old Aug 14, 2007 | 05:36 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
You need to figure out which system is shutting off. Does your radio also cut out?
It may be the fuel pump wires.
Old Aug 14, 2007 | 09:02 PM
Engine: 350 tpi
it seems to just shut down with out anything shutting off. but the security light does come on. if i have the stereo on loud i cant tell the car shut off untill i step on the gas. is there a spot that i should look first for the fuel pump wires?
Old Aug 15, 2007 | 04:10 PM
Engine: 350 tpi
ok just randomly out of curiosity i was driving and i hit my steering column right above the ignition cylinder and the car shut off. radio stayed on and the security light turned on. i tossed it in nutral and started it up agian. tried to hit the colmn to get the same results but nothing happend. i kinda pulled the key back just a bit and it shut down instantly ( and it was way too easy to turn the key i hardly even touched it)
so im guessing this is my problem. can i buy a new ignition cyclinder with keys some where? i dont want to keep my vats system overrided though id like to reconnect it. and any one know what fuse i pull to stop the horn? wheni pull the horn cap off the steering wheel it always honks alot and its annoying!
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
