Is converter lock up controlled by speedo on a 89 IROC?
Old Aug 19, 2007 | 10:52 AM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
I have an 89 IROC Z and am in need of new gauges. I've been told that on the 90-92 that the speedo controls torque converter lock up and a few other things on the speed density set up. I have MAF and a cable driven speedo. What does the cable driven speedo have to do with my computer on my IROC. I've been driving it with no noticable problem with the speedo cable broken so what is the difference?
Old Aug 25, 2007 | 10:57 AM
spacgost79's Avatar
Car: 88 iroc-z
Engine: 5.7 zz4
Transmission: megaraptor 700r4
Axle/Gears: 3.73 10 bolt posi
Re: Is converter lock up controlled by speedo on a 89 IROC?
the speed sensor is inside the speedo head ,so whith a broken cable and the speedo not working the ecu does not know if & how fast you are moving so it cannot lock the converter ,so you are always driving around with the converter unlocked................ eventialy it will kick a check engine lite
Old Aug 25, 2007 | 11:12 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
It is not great for the transmission either, but mostly is only bad on the highway.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Aug 17, 2015 09:42 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
