Anyone wired switches up to their headlight motors
Old Aug 22, 2007 | 10:07 AM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
Well I just did Mine are an 86 so its 3 wires, but one is for an overload thing for the mercury switch(i think) inside. you just cut it and wrapr tape around the end, its not needed.
I had a power window center console in my car(but mine are crank) cause the kid i got it from wanted to convert it but getting the console is as far as he got
so I wired the headlight motors to the window switch and it works
HOW to do IT: make sure your power window switch has 4 prongs on the bottom.
Step1: make a power wire to come from the fuse box and put it on one of the prongs
Step 2: now ground it, ( i did mine on some bolt by my shifter) but make sure the ground is parallel to the power wire.
Step 3: take the Blue wire with a white stripe from each motor and put they on the last 2 prongs.
Viola push the switch up they go up, push it down they go down .
you might have to turn the swtich around so when you push it up they go up vice versa.
But a Very easy fix to the electrical problems these all get.
Mine would go up and down when they felt like it, and had a constant draw killed my batt over night.
now its all good
a very easy cool fix I think.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 13, 2015 12:59 PM
