HEI Keeps Dying - Help Please!
Old Aug 27, 2007 | 11:11 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Twice this summer while cruising my engine has died completely (with the tach going to a "zero" reading even b4 the engine stopped turning over). After replacing the distributor (GM HEI coil in cap) everything was fine for a couple months until it happened again today. I believe I'm burning out my module but I can't figure out what would cause it. I'm thinking:
1. Excessive engine compartment heat?
2. Excessive voltage to the distributor?
Thats all I've got. I'd love some feedback because the problem shows no symptoms, the car just DIES.
Tyler
Old Aug 27, 2007 | 01:03 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: HEI Keeps Dying - Help Please!
The module needs the appropriate heat sink compount and also a good path to ground.
I had some bad grounding issues killing my 8-pin modules.
Old Aug 27, 2007 | 05:57 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Does it restart after it dies, or do you have to replace the module to get it going?
Could be that you have a bad/corroded connection and each time you are working around the distributor, you are correcting the problem. Check wiring to distributor.
Corky
Gunner242
Dec 25, 2015 04:49 PM
skinny z
Oct 5, 2015 06:23 PM
Luigytico09
Oct 1, 2015 08:46 AM
Damon
Sep 26, 2015 04:29 PM
