changed starter solenoid, still nothing
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay. So my car just doesnt turn over when i try to start it. I thought dead battery maybe. Nope im at 12-13 volts when car is off. I hve brand new altrenator, battery and starter solenoid. If I jumpstart the car with either a manual jumper, jumper cables, or recharge the battery really high, it will kick up and go. I will turn the ccar off, attempt to start it, and when i turn it over. There is nothing. Just the bzzz sounds of the key thing. Someone plese HELP ME!!!!!
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: changed starter solenoid, still nothing
When you turn the key to start and it won't crank, do lights dim or anything? That would be a sign of a battery terminal problem.
Lou
Lou
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Bad ground,...... ?? Either at the battery to body wire or the starter to the engine block itself.
Possibly bad / broken positive wires running to the starter & or soleniod ???
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I found out it was a bad battery. It could only hold 10-11 volts and that wasnt enough to crank. What is bad is that battery is 1 month old
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
lol didnt think 2 autozones a discount autoparts my volt meter and a month battery would bullshat me
92camaroJoe
Aug 13, 2015 06:07 AM
