90 Firebird Hatch Pulldown Help!!!
Old Aug 31, 2007 | 11:04 PM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
I did search, but need some specifics. The motorized hatch pulldown is broke. The hatch latches shut but wont pull down and engage (can not hear the motor), the key will not open it, only the release button from inside the car will pop it open. I inspected it while still on the car, the motor is loose (it wiggles when I touch it) and when it comes in contact w/the copper part it starts to run. So its broke free from the copper contacts (from what I can see) and is not working. I had to disconnect the hatch light (cause it stayed on).
I went to TDS website, based on this, what specifically do I need to get to repair it? The plastic sleeves do look bad and cracked and the motor works so...?????
Old Sep 1, 2007 | 04:47 PM
Car: 1990 Firebird
Engine: 3.1
Re: 90 Firebird Hatch Pulldown Help!!!
Does this sound like I can get away with repairing it or do I need to replace the whole thing??? Any help please...
Old Sep 2, 2007 | 12:19 AM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
You may have to replace the motor if the contacts are broke. Make sure your relay is good, power coming to it..Mine is like yours but the key will open mine, but the power release want work at all. Mine is in a thousand parts right now, so it's not a problem. It would work occasionally before it quit.
Old Sep 2, 2007 | 09:22 AM
Car: 1990 Firebird
Engine: 3.1
Radtoy89, I do have power to it...
-It seems a top chunk of the plastic housing (cheap *** GM) that hold the motor in place has cracked off and the motor is hanging off the contacts. If I wiggle it to make contact the motor will run (although since the hatch is up it should not be running right?) Electric/ground issue I assume since its broken??
-The key did work to pop it now (did not the other day).
-Can I get away with a rebuild kit or should I hit ebay for a whole replacement?? (they are not cheap!!)
-Wish I could just go back to non-motorized hatch release (any thread on how to do that???)
Old Sep 3, 2007 | 10:04 PM
Car: 1990 Firebird
Engine: 3.1
To hell with this motorized crap! Motor housing is cracked, nut is stripped, so I turned it into a MANUAL like it should have been in the 1st place. I jammed some 2 1/2" pieces of wood in the tracks to keep it in the down position (they ain't movin or shifting I made sure of that) and VIOLA, it closes and opens like it should again w/o the pulldown BS! and the key works as well as the release from inside.
Old Sep 6, 2007 | 08:09 AM
Jeff89formula's Avatar
Car: 89 formula
Engine: 305 TBI
If you want the motorized hatch to work again, go to your local scrap yard and pull a the whole unit from another car. Then use the two to make one good unit, that's what I did and mine works great. Don't forget to lube the plastic gear and tracks while you have it apart.
Old Sep 6, 2007 | 09:27 PM
Car: 1990 Firebird
Engine: 3.1
I like it better as a "manual", no more headaches this way and it shuts tighter than before. What was GM thinking...
hydrolic144
Sep 8, 2015 06:55 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
madsv1000
Aug 20, 2015 06:45 AM
Randomtask2
Aug 13, 2015 01:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
