Instrument Panel fuse?
Old Sep 8, 2007 | 11:49 PM
m_murphy20's Avatar
Car: '87 Iroc Z28
Engine: crate 350
Transmission: stock 5 sp.
Hey, today I was unplugging out the non-functioning climate control unit, and was ingorant to unplug the negative terminal of the battery like I should of, and I come to find that the key was in the 'run' position . I snipped the light bulb wires, and see the spark. (I had the assumption the power was off because the bulb was dead) Next thing I know, the gauge backlight doesn't work. I'm not sure about other things not working...thats all I notice. (I tested the now cut wire, and that wasnt hot)
I am reasoning that it must be part of a circuit that controls the 'other' lights when your headlights are on, and that I blew a fuse on that, but I didnt do too much looking around because I was low on time. Obviously, I don't care about the "climate control light," but I do need my gauge lights back on. Where should I start?
Thanks for your help,
Matt
Old Sep 9, 2007 | 11:00 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Instrument Panel fuse?
Just insulate the wires you cut and replace the blown fuse,............
Old Sep 9, 2007 | 12:53 PM
m_murphy20's Avatar
Car: '87 Iroc Z28
Engine: crate 350
I checked out the fuse box to look for a blown fuse, and none looked blown. Which fuse would it be to take a closer look?
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
kkirch15
Sep 30, 2015 04:44 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
