Tach Prblems
Old Sep 13, 2007 | 09:19 PM
Cash25's Avatar
Car: 1986 Iroc Z-28
Engine: 5.0 305 TPI
Axle/Gears: Stock
Tach Prblems
I have a 91 Camaro RS, when I place the key to Acc. the tach goes from end to end, but never recovers. The tach stays all the way at red line when the car is running. Any suggestions?
Old Sep 14, 2007 | 07:00 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Tach Prblems
It is very likely that the tach driver module is bad. It's the small circuit board inside the instrument cluster, just behind the thachometer. You can replace it with another one or you can try to fix it. Search for a Tachometer Fix in this forum and you'll find a lot of links but one in particular that contains a lot of good advice.
Lou
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
