VATS Question
Old Sep 15, 2007 | 02:53 AM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
VATS Question
I have done the VATS Bypass mod. I know it's not supposed to be described here from what I've read. I won't go into detail and need to know.
Will bypassing the VATS cause a battery drain? You know, by leaving the "bypass" in? Should I run it through a switch and only switch it on when I'm ready to start the car?
Thanks a lot.
I'm having a battery drain problem and since this is the only thing I've changed if that would cause the ECM to stay powered on and drain the battery.
How much is a new ignition switch? Would it be worth it to change it instead of bypassing it as far and worrying about the battery drain?
Old Sep 15, 2007 | 03:09 AM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Re: VATS Question
This is on my 89 IROC, forgot to mention that.
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
