alt not charging
Old Sep 15, 2007 | 11:47 PM
thrashin420's Avatar
Car: 84 trans am/86 camaro
Engine: 305/350
Transmission: 700r4/700r4
alt not charging
my 86 camaro is charging at 10v. i start the car and pull the pos cable from the bat and it dies.my alt is new i had it tested and they say it was good and bought a new one and i also got a new bat. and still not charging right. i hope someone has an idea
Old Sep 16, 2007 | 07:25 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: alt not charging
check the fuseable links . [ large orange wires near battery ] feel them , if you find a soft spot thats your problem . also check all grounds . fuseable links can be repaired or replaced like any regular wire .
Old Sep 16, 2007 | 10:48 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I had a faulty ignition switch give me similar symptoms. The alternator wouldn't charge, and no power to accessories like the cooling fan and HVAC blower. After I charged the battery, I had power to start the car and drive, but not for any distance. Just an idea.
Old Sep 16, 2007 | 09:38 PM
Engine: 305/350
I put a test light on the single wire on my alt and no juice and my trans am is hot when the car is off. the wire from the starter is bad. so i jumped my alt to the pos cable. it works........any problems i might have for doing this let me know plz thanx for the help
Old Sep 16, 2007 | 09:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like you've got a burned fusible link.
Old Sep 18, 2007 | 09:21 PM
Engine: 305/350
ok now it charges but at idle it charges at 10 then when i drive it is at 13
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
