removing computer. some questions
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok i am in the process of removing my computer, went carbed. will i need to keep the relays for the fan and fuel pump? also will my speedo still work? it is a 91. if not how can i fix that?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: removing computer. some questions
You'll need the fan relay to run the fan, with some means of controlling it without the computer. You'll need the fuel pump relay if you plan on using the in-tank pump. The speedometer will still work as long as you don't hack up the wiring.
do you know what the wire for the sppedo looks like? that way i am sure that i won't cut it.
ok, better question. what does the wire connect to? is it mixed in with the ecm wires?
