whole mess of problems
Old Sep 17, 2007 | 01:02 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
so i just swapped an l98/700r4 from a 90 iroc with entire engine wiring harness into another 90 iroc lb9 car. I keep discovering problems such as the starter relay randomly died (mind you both cars ran and everything worked) and now when the lights are on, the turn signals don't flash... on the left side the front marker light doesn't come on and on the right the rear sigal doesn't come on. But when the lights are off, the left side flashes and the right still doesn't(hope that makes sense) Bad grounds maybe? or maybe I should swap in the dash and wiring harness from the l98 car too? Also one more stupid question... if theres no gas in the tank, do you still hear the fuel pump prime/turn on when the key is on?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
soarestransam
Aug 24, 2015 08:15 AM
