86 to 89, very different. And VATS?
Old Sep 18, 2007 | 09:27 AM
mmaki's Avatar
I had a beautiful 86 WS6 TA that eventually succumbed to rust and sat in my back yard. Now, 10 years later I get around to buying a 89 base model with a solid body. The idea was to turn the 89 into the 86 TA.
The problem is, I have run into very different wiring on almost everything and it almost would have been easier to swap all wiring from the older one to the newer. My issue right now is interfacing the TPI engine harness with the 89 wiring. Yes, the connectors snap right in, but the wiring to the connectors is different.
Other issues, aside from engine controls:
windshield wiper system is different
washer pump is different
heating and AC is different
headlight activator system is different
taillight wiring is different
Also the 89 has the VATS system. The VATS system controls the signal to the starter but I notice it also sends a signal to the ECM. Now I have put a not VATS ECM into the car. Must I now remove the VATS?
Mike
Old Sep 23, 2007 | 12:24 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: 86 to 89, very different. And VATS?
just a thought but why not just re-pin your 89 ECM harness to run TPI seems like alot less work.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
Winchester1094
Sep 15, 2015 09:48 AM
