is there a way to test a msd 6a box?
Old Sep 20, 2007 | 08:55 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
im new to msd ignitions and i want to test and see if my box is still good. i got it used when i bought my motor. when key it turned to accessory the coil isnt even getting 1 volt of power?? battery is good
Old Sep 20, 2007 | 09:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: is there a way to test a msd 6a box?
That's normal.
Old Sep 20, 2007 | 09:16 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alrihgt i dunno if it makes a difference but i have an msd distributor with magnetic pickup and a blaster coil. im pretty sure the coil should be gettign 12 volts when cranking right?
Old Sep 20, 2007 | 09:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The MSD is a capactive ignition, the coil primary will only have power for a brief instant when the coil actually fires.
If you're using the magnetic trigger, use a piece of wire to short out the green and purple wires in the magnetic pickup connector, and then pull the wire out. Each time you pull the wire out you should get a spark. Usually you can actually hear the box click when it happens.
PurelyPMD
May 5, 2016 04:57 PM
codeysabatini
Nov 10, 2015 04:07 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
86CamaroDan
Sep 29, 2015 10:08 PM
buckshot63
Sep 10, 2015 09:15 AM
