Overactive popup headlights?
Old Sep 25, 2007 | 11:25 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Hey guys, my firebirds lights keep popping up when I hit the parking lights. They dont light up until I hit the headlight switch as normal and they lower as normal. What gives?
Old Sep 26, 2007 | 02:07 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: Overactive popup headlights?
sounds like a shorted switch, might be able to clean up your switch but i know you can get replacements through year one.
Old Sep 26, 2007 | 02:49 PM
Orinackra's Avatar
I figured it out, it was a problem with the motor. I put a motor in it from my old car, and it started working properly. Thanks for the reply tho!
Old Sep 26, 2007 | 04:55 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Orinackra,
Please explain a little more as I have the same problem. Also, my pass side rebuilt is not coming up 3/5's of the time. Dangerous for me to drive as police would get me, happened yaers ago before I bought the rebuilts. Thanks! Andy
Old Oct 7, 2007 | 10:42 AM
Orinackra's Avatar
What was happening was when I hit the switch to turn on just the running/fog lights, the headlights would pop up, but not light up. When I hit the headlight switch, the lights would come on. I believe when I hooked the battery up, the motor would spin for about 15 seconds. Once I replaced the motor it started working normally. It was only one side too.
Old Oct 8, 2007 | 01:37 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I've had several customers with the symptoms you describe. Their problem went away when they repaired their headlight motors using my headlight repair kits (207280 or 209280). Here's a link customer reviews that mention the kit solving this particular problem:
http://www.top-downsolutions.com/pro...&reviews_id=43
http://www.top-downsolutions.com/pro...&reviews_id=79
Lon Salgren
Top-Down Solutions
Old Oct 8, 2007 | 01:43 AM
lonsal's Avatar
Lon Salgren
Top-Down Solutions
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
