Under Dash Lights and Window Question
Old Oct 6, 2007 | 07:56 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Well, I have been searching and searching and found nothing so I have to ask it. My car did not originally come with under dash lights (87 Camaro SC) and I am trying to add them, I have the two light holders with white and orange wires, but can't figure out where to wire them to.
Also, I just need some clarification on whether or not Camaros have power window relays for any reason.
Old Oct 8, 2007 | 01:33 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: Under Dash Lights and Window Question
Take a look at this thread for the under dash convinence lights.
https://www.thirdgen.org/forums/inte...t=#post3330084
All the third gens with power windows only had the up/down switches and a power window motor in each door. No relay. The power door locks did have a relay.
Dave
Old Oct 8, 2007 | 07:37 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Thanks for the help, very informative. I went to the junk yard and was looking around at some of the Camaros wiring and saw a plug that on my car is just hanging there and noticed that it was plugged into another connector that went to the courtesy lights. I just pulled the entire under dash light wire harness out, came home, and plugged it in without any problems .
Thanks for the window information, glad to not have to mess with another relay after the defrost and power lock ones
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
