Easy DIY electronic turn signal flasher.
Old Sep 30, 2007 | 08:16 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Pulled the flasher socket from my 97 Grand Prix, and installed one of my modified flasher modules with adjustable timing. Installs in 5 minutes, with no alterations to the factory Firebird wiring.
Crimp a 1/4" male spade to the blue and violet wires of the new socket, and insert the tabs into the F-body's stock 2-pin thermal flasher socket. In my case, blue to blue, violet to violet. Be sure to observe polarity if your socket differs. Ground the black wire, and enjoy turn signals that don't vary with engine load!
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
