Raise headlights Manually.
Old Oct 1, 2007 | 03:52 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Hi,
I tought it was possible to raise the headlights manually on 82-92 Firebirds by twisting the black ****/diall beside each headlight. I tried this but nothing happened. Is this just in my imagination or is it possible?. The headlights go up and down normally from the light switch inside the car so I guess that the motors are fine.
Thanks.
Old Oct 1, 2007 | 06:41 AM
Stephen's Avatar
Car: 87 GTA
Re: Raise headlights Manually.
Yeah. But it's S L O W. Keep turning the ****, and see if they go up. It takes several turns just to engage and start them moving, muchless it's like 3 turns, to go up/down MAYBE 1/4"
Old Oct 1, 2007 | 07:07 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2 very slow process. If youve ever watched them when they work on their own, you will see them turning very fast and a whole bunch of times.
Old Oct 2, 2007 | 02:28 AM
gholian's Avatar
Engine: 2.8 V6
Thanks for your replys. I will try and raise them this evening.
Old Oct 2, 2007 | 06:24 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Could be that the little thingies inside the headlight motor are disintegrated to dust. If the thingies are gone, then you can twist until the cows come home - try pulling them up. If everything inside the headlight motors are original, chances are you will be rebuilding the gear drive. Part that goes bad is dirt cheap - just takes your sweat equity to fix.
Corky
Old Oct 2, 2007 | 06:31 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Turn the **** counter-clockwise.
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
