Getting Rid of F.I. Wiring?
Old Oct 3, 2007 | 02:39 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Well I wasn't sure where to put this but...my car is a 1987 that was fuel injected and was converted to carb before I bought it...the people who owned it before left all the fuel injection wiring in there, how would i go about removing this wiring, could i simply just find something that is unplugged and trace in back and cut or what? Any suggestions are appreciated!
Old Oct 8, 2007 | 09:29 PM
kerplunk318's Avatar
Re: Getting Rid of F.I. Wiring?
What I did when I went to a carb was unplugged the computer under the dash and feed it into the engine compartment. From there I used a wiring diagram to determine which wires could be removed. Alot of the circuits cannot be completely removed. But pretty much when you find a connector that looks like its computer related check and double check the wiring diagrams and wire colors. I ended up removing a ton of wires. Good luck
Old Oct 8, 2007 | 09:46 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I also have an 87 that was converted from FI to carb. I agree that you should look at a diagram to figure out which wires were necessary for your FI motor. Is your car currently running? What I did was figured out the wires, (I cut a lot near the heater box) and cut em about 1 ft long maybe and folded em back and taped them with electrical tape and stuck em in the loom.
Old Oct 8, 2007 | 10:15 PM
mbolte's Avatar
Car: 1987 Camaro
ya the car is currently running, just kinda looking for a way to clean up the engine and maybe a project for thanksgiving break
RazorN8
Jan 7, 2022 11:44 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
stalkier
Aug 21, 2015 01:54 AM
355sbcTPI
Aug 19, 2015 04:38 PM
