Injectors won't fire
Old Oct 6, 2007 | 10:34 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
I cant figure out my injector problem...I have been struggling with vats...I have put the resistor in, CORRECT resistance, it got the starter relay going, but it did not get the fuel pump working or the injectors firing...so I ran a wire to the fuel pump relay (red wire) to turn it on on command and off on command...(toggle switch, then changed my mind and just ran it to the fuse panel so it would only turn on when the key is turned *on*)so I can get it to crank, get the fuel pump turned on, but I cannot get it to start and run....if I prime the throttle body it will fire, but will not idle, if i feather the gas pedal it will barely run, it seems like it is not getting near enough fuel, well barely any really....anyone have any ideas? If it would be helpful I can post a video of what it does...ANYONE please help me, this really sucks
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
