help! dont know what happened!
Old Oct 10, 2007 | 11:23 PM
IrocKid89's Avatar
Car: 1988 Camaro IROC-Z
so i have a 1985 z28 with a 5.0 and qjet. i was replacing the plug wires, cap, rotor, and coil and now the car wont start. not getting spark at the plugs. dont know what i could have done wrong, its a simple task that i have done many times. im completly boggled. any ideas as to what might have gone wrong? and why i can crank the motor over but it wont start? help is appreciated. thanks to all.
Old Oct 11, 2007 | 12:02 AM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
Re: help! dont know what happened!
ok take ur air filter off and then check coil wire did
u put it back on? its possible u put the cap on wrong and the rotor hit the cap and broke the rotor has happened to me before. check the wires coming out of the distibuter if u have old style two plugs check if wires were pulled from plug housing write back if u dont figure it out? stevo
if one of those wires are off one of them gives ur dist power when u turn key on
Last edited by stevo the torpe; Oct 11, 2007 at 12:03 AM. Reason: Automerged Doublepost
Old Oct 11, 2007 | 11:58 AM
IrocKid89's Avatar
it has the hei ignition, so the coil is over the distributor cap. and i inspected the cap, nothing is broken, and everything looks perfect in there. the plugs that plug into the cap/coil are in good condition. plugged in, everything looks like it should be working properly, i cant figure out what happened. could the spark plugs be shot? i would think the engine would make some attempt at starting though. any clues? i need to get this thing back on the road. will be checking back periodically and reporting my findings. thanks.
Old Oct 11, 2007 | 06:26 PM
Towman84Z's Avatar
make sure your plug wires didn't get out of the firing order
Old Oct 11, 2007 | 08:00 PM
oldyellow49's Avatar
Are you getting spark at the plugs? Be careful and use a spark tester (only a few bucks) the HEI puts out a lot of voltage.
Old Oct 11, 2007 | 08:36 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
+1
also, you didnt accidentally unplug the pickup coil from the module did you? (Not that I see why you would have)
Old Oct 12, 2007 | 02:40 AM
Car: 91 maro
okay well did u check the rotor button? it could be broke ? that or the main terminal that touches the coil tab in side the distributer in the center wich sends fire to each plug/the fire runs through the rotor button.it doesnt matter if its out of order it would still have fire.take an extra plug u have laying around take one of ur plug wires off and put the extra plug in lay it on the block and turn it over (best if done with 2 people or in dark) thats how u see if u have fire.yea if u dont have fire take the rotor button off and see if it is good.
and if that dont work try ur old coil
did u gap ur plugs?and when u turn ur key on is the fuel pump comin on?
Last edited by stevo the torpe; Oct 12, 2007 at 02:44 AM. Reason: Automerged Doublepost
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
