'SECURITY' light on - car won't start-HELP!!!!
Old Oct 14, 2007 | 10:26 PM
1990Camaro305's Avatar
Car: 1990 Chevy Camaro
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
Just bought a new battery today. The old one wasn't bad but I'd rather have a new one before winter. After I hooked it up car is not starting. Not even cranking.... dead!!!
SECURITY LIGHT ON A DASH STAYS ON - WHY???
WHAT CAN I DO??????
PLEASE HELP!!!
Old Oct 15, 2007 | 12:49 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Re: 'SECURITY' light on - car won't start-HELP!!!!
Hmm...unfortunatly I have not had this problem, but the one time I had dummy lights come on with no crank it turned out to be my ignition control module. Check that... (if you don't know what that is, its the little U shaped control unit directly under your distributor cap.
Old Oct 15, 2007 | 01:30 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Never had the problem myself, but from seeing similar posts in the past, it sound like a VATS issue. Either the VATS module or a broken wire in the ignition lock cylinder.
https://www.thirdgen.org/vats
Old Oct 15, 2007 | 04:25 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I bet it's that damn VATS....
Easy fix to bypass it entirely... Anti Theft systems are great (and VATS is pretty good, and simple) but when you cant use your car any easier than a car thief can, it's time to cut 'em loose.
Old Oct 15, 2007 | 06:25 AM
Engine: 305 V8
Axle/Gears: stock
I'll try to fix it today... THANKS
Old Oct 15, 2007 | 04:25 PM
86transamkid86's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Axle/Gears: 2.73/stoke/soon to be 3.47
i just ask my brother wut he had to do he has an 89 rs and he said his had a switch under the drivers side dash. and after you flip the switch let it sit for like 10 min. then start it, but we dont know if someone before him put that their but good luck!!
Old Oct 15, 2007 | 08:37 PM
Engine: 305 V8
Axle/Gears: stock
Well I'll try looking for it. Thanks everybody. You know how it is with new projects. Just bought the car two weeks ago and starting on it.
Old Oct 26, 2007 | 03:02 PM
Quzyle's Avatar
Car: 1990 IROC-Z, 1992 Z-28
Engine: 5.0, 5.7
Transmission: one of each
Axle/Gears: Both cars have them!
I have the same problem. Did you get it fixed?
Old Oct 26, 2007 | 05:04 PM
Engine: 305 V8
Axle/Gears: stock
Yes I did. Previous owner had that problem I gues, so they bypass the ignition and disabled VATS with some wires and connectors. One of them was loose. I dont exactly know how to disable it, but I got lucky and I had to take steering column cover off and just check for loose wires. After cleaning and reconnecting it car starts and runs like new.
My advice: it seems like VATS problem is so common, that you may find somebodys work when you take off the cover. Just check it for loose connections and GOOD LUCK. Check two yellow wires going up to the ignition switch!!!
Old Oct 26, 2007 | 05:09 PM
Engine: 305 V8
Axle/Gears: stock
THAT'S MY BABY...
Attached Thumbnails 'SECURITY' light on - car won't start-HELP!!!!-camaro-001.jpg   'SECURITY' light on - car won't start-HELP!!!!-camaro-004.jpg   'SECURITY' light on - car won't start-HELP!!!!-camaro-002.jpg
Old Oct 26, 2007 | 05:13 PM
Engine: 305 V8
Axle/Gears: stock
just starting on it ..... winter project I guess...
Attached Thumbnails 'SECURITY' light on - car won't start-HELP!!!!-camaro-006.jpg   'SECURITY' light on - car won't start-HELP!!!!-camaro-003.jpg
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
