relay help
Old Oct 16, 2007 | 04:35 PM
laynlowz's Avatar
Car: 85 camaro
relay help
ok well i bought a 2nd compressor for my air ride,i read up on how much these 2 will draw and its 32 amps
now i read up on afew forum and they run 2 usually.i recently bought a relay that is 30 amps
now my question is my new relay is a 5 pin so it has enough spots to run both compressors can i run it all off this 1 relay or will this cause problems?
i dont mind wiring up the 2 but its just alot less wiring i have to do if i can run it off the one is all
so any help here would be great
Old Oct 16, 2007 | 05:07 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Re: relay help
Well it depends on how many amps the compressor pulls. Realy at a point of too much power, at my shop the cars we do with big audio or air ride. We use a isolatore(SP) witch is like a relay as it only conects power when it has a switched power input. Same thing you see in older cars under the hood for the starter.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
