Starter wiring problem
Old Oct 17, 2007 | 07:25 PM
Bledlok's Avatar
Car: 92 RS camaro
I have a 90 camaro rs 305. My problem is the other day when i got under my camaro it looks like a wire has been cut off the starter and i don't know what it was or where it should go. It was one of the red wires. Does anyone have a diagram they can post for the wiring and where it wires to?
Old Oct 17, 2007 | 08:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Starter wiring problem
an easy was to figure this out is, what does not work?
there are a couple red wires coming off the started, on for the blower, one for the radiator fan, accessory power, ect.
What fan setup do you have? is it mechanical? if so maybe it used to have a electric and the previous owner cut the wire at the starter.
Old Oct 17, 2007 | 09:04 PM
Bledlok's Avatar
Car: 92 RS camaro
Well... as of right now basicly i'm trying to get the car running. When i turn the key the engine rotates slowly then stops. I've checked the batterys/altenator/starter/celeniod at auto zone and they are all good. but back to the point. since the car doesn't run at the moment it is hard to tell what works and what doesn't. That is why i want a wiring diagram (preferably one easy to read) So i can see where all the wires were supposed to go.
Old Oct 18, 2007 | 05:35 AM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Try this http://austinthirdgen.org/mkportal/m..._continued.gif
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
