Help! No fire up!
Old Oct 19, 2007 | 05:48 PM
Crawforj's Avatar
Help! No fire up!
So i just put a tpi engine into a shell and ive wired up everything. But, it isnt turning over. The dome light and power locks work except they are very weak. The radio works perfectly and the fuel pump and windshield wiper motor are working too. The starter is good I tested it and its getting power. What are some possible problems? Im pretty sure all my grounds are connected...
Old Oct 19, 2007 | 09:39 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Help! No fire up!
i have the same problem but im suspecting the ground for my starter cuz mine only works sometimes its almost like it dont get the power the starter is fine as far as i know and if its not any connections im checking my ignition too as i just had it apart
Old Oct 20, 2007 | 02:13 AM
Crawforj's Avatar
I found the problem, it was a connector under the dash that needed a jumper cap to connect the two wires. Now its cranks but the coil has no spark, but the wires and plugs are brand new and the distributor is about 4 months old and was working perfectly when it was removed. Tried two coil packs too. Both worked before hand... Im stumped...
Old Oct 20, 2007 | 09:45 PM
Brennan's Avatar
i found my problem well sorta, my ignition dont work when my wheel is adjusted up butt when its down it do(tilt steering) but anyway this aint about my problem did you rotate the distributer and check connections?
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
