hood light mounting ?
Old Oct 21, 2007 | 04:12 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i want to get an under hood light for my 83 bird. i know how it works and all but i was wondering where to mount it and in what direction so the mercury switch will work properly. also, what do i mount it to? not the hood itself so i guess the reinforcement panels?
anyone have a pic or anything?
Old Oct 22, 2007 | 08:45 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: hood light mounting ?
Doesn't matter where you mount it, anywhere on the hood will do. Mercury switch should be positioned so that when the hood is up, the mercury is over both contacts (to make a complete circuit). If you can't see the mercury, use a continuity testor to find out what position it does and doesn't make a complete circuit.
Old Oct 23, 2007 | 01:44 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
OK
These are from an 82 Camaro Hood. Note this hood has the air induction flaps for the TBI crossfire engine.
As Douchermann mentioned, it probably does not matter to much where you put the lamp assembly as long as it clears the air cleaner, etc. when the hood is closed. Note that you will need to run a ground wire from the lamp back to the fender frame for a good ground. Look in the factory assembly darwings for some ideas. The factory drawings are for the 82 Camaro model year. However, many of the details were used for a number of years...
See this thread for one of the photos, as the board will not let me upload it twice.
Cables hanging from under hood
Dave
Attached Thumbnails hood light mounting ?-camaro_hood_014m.jpg   hood light mounting ?-82_camaro_under-hood-lamp-u26_1.jpg   hood light mounting ?-82_camaro_under-hood-lamp-u26_2.jpg
Last edited by 82CrossFire Z28; Oct 23, 2007 at 01:54 AM. Reason: Edited Text and added two attachments
Old Oct 23, 2007 | 02:08 AM
awesome guys. thanks for the help. nice pics 82crossfire.
Old Oct 23, 2007 | 11:37 PM
punkdude908
Thanks. If you want to see any other pictures of the under hood lamp let me know, I have several more on the hard drive. It also is not much of a problem to pop the hood and get a shot or two.
Dave
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Omega
Aug 10, 2015 12:46 PM
