Tach with my 6AL box
Old Oct 29, 2007 | 09:51 PM
chevrolet87's Avatar
I have an 87 Sport Coupe that originally had an LG4 motor in it, we just had a new motor put in it with a full MSD setup. I also just got a 145 speedo out of a 87 and wanted to know how i would wire it. I know there is a plug on the box but would i just run a wire from the back of the tach to there or what. Any help would be greatly appreciated, thanx guys
Old Oct 30, 2007 | 12:13 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Tach with my 6AL box
The speedo should be a direct swap.
If you hook up the MSD 6AL box according to the directions, your tach should work just fine. However, some carb engines have a "tach filter" on the firewall, which is just a large resister. You will need to either bypass that, or get the tach filter adapter from MSD. I am not 100% sure, so hopefully someone else will reply here.
Old Oct 7, 2009 | 01:01 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
TTT...
I am going to hook my 6AL again and remember last time the tach acted screwy. I cannot remember if this was with the carb or FI motor, however.
I did convert from FI to carb so I would assume I do not have this tach fiilter on the car.
I'm just trying to get my last JEGS order inline with what I do and do not need.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
Zell1luk
Sep 29, 2015 10:36 AM
Eric-86sc
Sep 28, 2015 11:37 AM
