HELP!!! SPEEDO,FUEL, PRESSURE GUAGE PROBLEMS!!!
Old Nov 8, 2007 | 07:30 AM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I don't know what is going on!!! I was driving this morning and decided to stop for gas because I was running alittle low. I pumped that gas and got in the car. I started the the car and noticed that the fuel gauge was way past the full mark and I only put $10 in the tank. I figured wierd. When I started driving, i noticed it seemed like the speedo was stuck and as I kept driving the speedo kept going too. now it is sitting way past the 145 mark.... also I noticed the oil pressure gauge isnt working.... Everything on the right side of the cluster is working fine. I tried pushing on the cluster figuring it would help but no go..... I need some advice or help. Thanks in advance for any help.
Old Nov 8, 2007 | 02:29 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Re: HELP!!! SPEEDO,FUEL, PRESSURE GUAGE PROBLEMS!!!
Join the club!.. the gauge clusters are notorious for failing.. what you can do is search the forum and check the symtoms or do what i'm doing and wire up autometer gauges
Old Nov 8, 2007 | 02:52 PM
Autometer guages are expensive.... I don't think anyone offers and aftermarket cluster pod for the 90-92s... put it back to stock.
Old Nov 8, 2007 | 02:57 PM
Covan's classic gauges
Old Nov 8, 2007 | 07:50 PM
They only make them for 82-89... I have the newer style cluster.
Old Jun 18, 2009 | 06:22 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Old Jun 18, 2009 | 10:30 AM
it turned out that when i put the cluster back in, i messed up some of the contacts. I straightened them out and put it back in and wala. it worked.
Old Jun 18, 2009 | 10:34 AM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Good job there. :P
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
