Door lock relay
Old Nov 10, 2007 | 05:23 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Door lock relay
Whe i try to lock the doors with the power lock. The metal box under the dash towards the floor makes clicking sounds. I think its the relay and i think its bad. The power locks won't work. What is it?
Old Nov 10, 2007 | 05:29 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Re: Door lock relay
Sounds like the relay is bad. Try replacing the relay and see if that helps.
Old Nov 11, 2007 | 02:53 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: Door lock relay
yeah ill try
Old Nov 12, 2007 | 12:21 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Door lock relay
Did you check your PWR ACC 30A circuit breaker? It powers the door locks. So if the relay clicks but doesn't lock/unlock, it might be the breaker. (the relay itself is powered from the Courtesy fuse).
Lou
Old Nov 13, 2007 | 06:48 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: Door lock relay
ill check it out
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
