MAF sensor/relay?
Old Nov 19, 2007 | 05:33 PM
Blue Meenie's Avatar
MAF sensor/relay?
alright, so my problem is I'm pulling a code 33, MAF sensor. its on an 87 trans am 305 TPI. the odd thing is though, it usually runs fine...while the SES light is on. if I crank it up and the SES light doesn't come on, it usually comes on shortly down the road, no worries...runs fine. however if I crank it up and head out in a hurry, and the SES light doesn't come on, it will start bucking and shuddering around half throttle making it almost undrivable in any kind of traffic situation.
is there anyway I can bypass the MAF for the time being? I have a feeling its a bad relay but I need to wait till payday to get a new one
Old Nov 19, 2007 | 05:46 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: MAF sensor/relay?
Unplug the MAF. That will force the car into limp home mode... It will at least drive.
Old Nov 19, 2007 | 08:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a new spray cleaner designed for MAF sensors that is on the market now. I believe that it is marketed by CRC and it is carried at most Advance stores. It comes in a gray can.
Old Nov 19, 2007 | 09:22 PM
k, thanks guys
Old Nov 21, 2007 | 11:51 AM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
has anyone seen much actual results with the MAF cleaner?
Most posts I ahve read on here, and back on my old BMW forum all said "tried cleaner, no change"....?
Old Nov 24, 2007 | 05:22 PM
ok, new development. turns out the previous owner replaced a bunch of wires with orange wire. I can't get to where they are spliced but I know that the three relays on the driver side of the firewall don't have their original colors. I'm also pulling a code 33 and 34. trying to make sure its not a wiring problem with the MAF before I have to go buy a whole new sensor. any ideas? again its on an 87 trans am, 305 TPI
Old Jul 28, 2008 | 07:42 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
ever find out what the problem was? i have the same issue now
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
