Fuel Gauge Broken????
Old Nov 25, 2007 | 02:24 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
HEre is a simple one.... SHould the fuel gauge mark Empty when the car is power down (no keys on ignition)? Mine fuel gauge stays on about 1/4. I disconnected thebattery and nothing. Prior experince on other cars tell me this is not normal. ANy ideas!
Old Nov 26, 2007 | 11:01 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fuel Gauge Broken????
Our gauges are designed in the way that once you turn off ignition (or disconnect battery), they are not supposed to show a correct reading. Meaning that they are free to move up, down, left, right, whatever.
It is completely normal to see a gauge move once you turn the key off.
Once you turn the key back on, the gauge will show the correct reading again. If so, your gauge is good.
Lou
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
