found bad wire
Old Nov 25, 2007 | 07:18 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
found bad wire
My car hadnt been running quite as good as I thought it should.Ive been running rich,fouling plugs for a while but with no codes.Been stumped.I was driving home the other night and my lights were dim and charge was low.Stopped and had it checked,bad altenator.Get a new one put it on,no better.Took it off to take it back and the black wire looked cut,and had a bunch of corrosion in it.Aparently it had been spliced and for some reason corroded through the butt connecter and shorted out and burned into the other wire it was next to.One red one black wire.The black one was the one that had the problem.I cut all the bad stuff out and rewired it and the lights all seem brighter than they have in quite some time.Car seems to be running better and doesnt smell rich.I havent really been able to drive it because its been raining for two days but it seems to idle better as well.Is it possible this bad wire could have been causing the running condition problems?
eightsixseven
Dec 16, 2024 01:50 PM
86IROC112
Apr 9, 2016 10:20 PM
bjpotter
Aug 12, 2015 06:06 PM
ZsTransAm
Aug 11, 2015 07:30 PM
antares57
Aug 6, 2015 07:47 AM
