clutch switch LS1/T56 swap question
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
i see the green and purple wires in the auto shifter connector. i also found the purple and green connector tied up by the fuse box. (car is a 1992 camaro rs auto). does this connector need to go to the clutch switch on the pedal? and can i leave the auto shifter connector alone if i use the connector by the fuse box? also, will my hatch release work? thanks guys.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: clutch switch LS1/T56 swap question
Yes it will work, but you need to switch the wires on the hatch plug located behind the radio and air duct. You will find a plug and another connector one marked auto and the other loose, just switch them.
rsrmoore
Aug 7, 2015 08:44 PM
