MECHANICAL TO ELECTRIC SPEEDO PROBLEM
Old Nov 30, 2007 | 08:21 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
I JUST PUT TOGETHER AN87 GTA AND SWAPPED OUT THE 700R4 TO A T-5 THE CAR IS CARBURATED NOW AND I SOLD OFF THE COMPUTER AND TPI. MY SPEEDO DONT WORK (EVERYTHING ELES DOES) I DONT KNOW HOW THE ELECTRIC SPEEDO WOULD WORK IN THESE CAR MAKING IT HARD TO TROUBLESHOOT. DO I NEED TO PUT A COMPUTER IN IT?? I KNOW THAT THE 2 WIRES FROM THE SENDER GO TO THE BUFFER (YELLOW BOX BY WERE THE COMPUTER WOULD BE) AND THE LITTLE GREEN/BLACK WIRE GOES TO THE "S" SIDE OF THE SPEEDO. THATS ALL I GOT SOME ONE HELP ME HERE
Old Dec 1, 2007 | 07:15 PM
Axle/Gears: YEP
Re: MECHANICAL TO ELECTRIC SPEEDO PROBLEM
does anyone know if i need a computer to get my speedo to work??
Old Dec 1, 2007 | 07:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have an 86, and i dont need the computer
what type of speed sensor is on the trans mechanical or electric? and how is it hooked up
Old Dec 1, 2007 | 09:25 PM
Axle/Gears: YEP
the car was set up with a 700r4 auto with an electric vss. i just switched to a t5 manual and found an electric vss and hooked it up. nothing no power goes to you vss and if you put power to one wire and drive it with a test light on the other wire you get nothing to the test light
Old Dec 2, 2007 | 01:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
are the drive/driven gears in the trans? is the sender good?
Old Dec 2, 2007 | 07:46 PM
Axle/Gears: YEP
yes all there and working
Old Dec 6, 2007 | 01:43 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
What car did the T-5 come out of? If it was originally for a cable driven speedometer you will have to change the tailshaft housing to an electric one.
The cable driven transmissions still had a vss mounted on the side after 85 I think but that was just for the ecm and cruise control. I am pretty sure that this is correct, maybe someone with more experience can chime in.
Jorlain
Aug 24, 2022 05:11 PM
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
g.l.mos
Aug 22, 2015 12:02 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
