92 RS Ignition problems
Old Dec 1, 2007 | 03:17 PM
Waxhawcat's Avatar
I have a 92 RS and the ignition is stuck in the on position. I can not remove the key or get the cylinder to turn back. It will crank but i have to unhook battery and other stuff to get it to shut off. I have removed the air bag and steering wheel but i am stuck. There is a small round pin i guess you would call it at the bottom of the shaft that i can not get off. it is very tiny. i have a book but it shows you using a U shaped tool to depress the shaft to release tension on this pin but my steering colum inside looks nothing like what is in the book. Can any one give some advise on how to proceed forward to get the ignition switch out so i can replace.
Please help!!!!
thank u
Old Dec 9, 2007 | 09:02 PM
speedboatermrfi's Avatar
Re: 92 RS Ignition problems
Hello there do you have a Harbour frieght tool co in your area you need to get a steering wheel remove get it is around 15.00 and it will make your life so much easier (make sure you watch how all comes apart ) and buy the way i dont think your problem is in the steering colum is this a auto matic car if it is the problem is in the center console
Old Dec 9, 2007 | 09:14 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Sounds to me that you have a broken ignition lock cylinder. I went through the same thing when the car was in the shop for something else - finished the job they were doing, started the car and moved it, then couldn't shut it off.
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
