Changing to Bosch 3 Wire 02 Sensor on 350 TBI
Old Dec 2, 2007 | 08:41 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
I'm converting the 1 wire 02 Sensor to 3 wire heated Sensor on my 350 TBI and i'm trying to figure out how to wire it. I'm installing a Bosch 3 wire for a 1995 V-6 S-10 chevy, read that was the one to use. The Sensor has two white wires and one black. On the three way connector it is marked A & B for the white wires and C for the black wire. I know one hooks to the wire from the ECM, one to a 12V hot wire and one to the ground. Anyone ever used a Bosch 3 wire Sensor? Which wire hooks where? Your help would be appreciated. Read a lot of posted threads for this subject, no help. Thanks.
Old Dec 2, 2007 | 11:35 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Changing to Bosch 3 Wire 02 Sensor on 350 TBI
Just did this on my 89 RS. I bought a 3-wire weatherpack connector for it, I forget the part number off-hand but it is a Dorman product found in the HELP! line. The black wire connects to the ECM and the 2 white wires are for the heater, polarity doesn't matter. I connected one to the pink/black (switched 12V)wire to my fuel pump relay and the other to ground.
Old Dec 2, 2007 | 08:12 PM
Fionnla's Avatar
Car: 85 Camaro S/C
Thanks Al. That easied my mind a lot. I had a thought that was the way it was hooked up, but wasn't sure and didn't want to roast a $50.00 Sensor. Thanks a lot, I'll order the female connector tomorrow.Later.
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
apo_bailon15
Mar 28, 2016 05:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
92purpz28
Aug 11, 2015 02:30 PM
