steering column/vats problem
Old Dec 5, 2007 | 06:20 PM
colbear92rs's Avatar
Car: 92 rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
ok i have a 92 rs, the lilt was real loose and the wheel moved around alot, so i bought a steering colum at the junk yard for the same car. had keys and everything i put it in, and the keys turn forward but it dosent crank, a buddy of mine said it might have something to do with the vats, help please
Old Dec 5, 2007 | 06:27 PM
Car: 92 rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
Re: steering column/vats problem
any help guys
Old Dec 5, 2007 | 07:30 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
it could have something to dow tih vats, but if you got a new steering coulumn, and wired everything the same, nd use the same key, it should work. im having almost the same problem with my car, it cranks but wont fire after the steering column was replaced. let me knwo if u solve ur problem, ill let u know if i find anything out.
also, on my lock/cylinder on my 87, the key thingy sticks out a little and the car wont crank, but i can push it in, toward the steering column, and it will crank, now that would be an easy fix.
Old Dec 5, 2007 | 07:44 PM
Car: 92 rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
well the column is not new, i got it from a car like mine, same year and everything, it came with the key, i hooked all the wires up and everything, i tried to start my car, and the keys went forward and the lights on the dash came on but didnt crank
Old Dec 5, 2007 | 07:50 PM
92WhiteZ28's Avatar
right, but the vats system isnt actualy in the steering column, its just wired through it. if u use ur old key it should work. just make sure you dont have any loose wires, also you could try to reset ur computer. check the inj fuses. make sure ur fuel pump is priming. all of my lights come on, turn signals work, and kmy car wont start either, but mine cranks. im so lost.
Old Dec 5, 2007 | 07:54 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
if your not using you orginal key the car wont crank if you using the key that came with the column the resistance is different you need to take your orginal key and the new key to the dealer and have the dealer cut you a new key that matchs the resistance from the orignal or just do a vats bypass which would be cheaper
Old Dec 5, 2007 | 08:00 PM
92WhiteZ28's Avatar
so the question is, how to bypass vats?
Old Dec 5, 2007 | 08:07 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
take a ohm meter test resistance on your orginal key how ever much it reads say for example 7800ohms go to radio shack buy some resistors that adds up tp 7800 ohms put them together test with ohm meter to make sure they make 7800ohms go to the bootom of the column find the orange strand of wires disconnect and reconnect with the resistors .
Old Dec 5, 2007 | 08:51 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
the answer to your problem is very simple.Take the ign. lock/switch out of your original column and replace it with the key tumbler in the junkyard purchase.The keys are different.I promise you,if you only replaced the steering column with one from a different car thats all you need to do.The answer is in the ign. key!That little black piece on the key is part of the vats.The key sends a signal to the vats module.As long as you have the vats module and ign. key from the same car (not just same year) you should have no problems.
Old Dec 5, 2007 | 11:39 PM
92WhiteZ28's Avatar
and say u dont have a key to match your module??? thats where im at.
Old Dec 6, 2007 | 08:44 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you don't have the key, you'll need to find the right key resistance. I think they have 15 different values total. It only takes some time and a few resistors. http://tpiparts.net/vehicle_anti_theft_system__vats_
Lou
Old Dec 6, 2007 | 09:16 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
The best way to test if the key is even the prob with out doing a lot of work is it just get the old colm with the old key place it in the floor under the dash, then plug in the orange wire from you 1st colm into the plug under the dash.
If the car starts then you know the key resentence for the 2nd colm is different. Then you can go throw the trouble of
1. switching the 1st key cylinder into the 2nd colm,
2. get a key made for the 2nd colm with the resentence of the 1st colm,
3. do the by pass with the resentence from radio shack (1st colm resentence)
But if there is no crank with the 2nd colm at all then the vats might not even be the prob, that is why you should just plug in the old colm to test don't forget to turn the 2nd colm key to the on position when testing. this will power up everything. i hope this helps and is not reparative of past posts.
PS most of the time when the colm is loose it just need the 4 screws tightened, they loosing up from people getting in and out of the car using the wheel to help them get out.
If you need a new bypass with the key and box i have one for sale just e mail me at gtafanatic88@hotmail.com
i can also get you a pic of it if you need it for reference
Old Dec 6, 2007 | 03:29 PM
Car: 92 rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
timmy how do you take the ign. switch out
backtothe80s
Sep 5, 2015 12:39 AM
Oenone
Aug 29, 2015 07:54 PM
overdriv
Aug 20, 2015 03:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
