need a run circuit wiring diagram
Old Dec 6, 2007 | 11:41 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
hi i need to bypass and include my ignition switch at the steering column. What happens is if my steering wheel lifts even a millimeter the car turns off. i know why it happens but i dont know if its the vats or run circuit doing it.
so if anyone has access to a wiring diagram baisicaly for what color wires these are at the steering column plugs i would appreciate it. i dont plan to cut them completely just add a switch that can connect them together to prevent my car from shitting off unexpectedly. also it is possible that it is no the run circuit causing the unexpected shutdown but the vats(also in the steering column from the ignition switch) and if you got a digram for that too i would appreciate you posting it.
Old Feb 6, 2008 | 06:42 PM
Engine: 383 HSR EBL
Re: need a run circuit wiring diagram
does anyone have the wiring diagram im looking for
it is definately the run circuit being cut so thats the one im looking for.
Old Feb 7, 2008 | 03:48 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
In the sticky "helpful link" up top should have what you're looking for.
Old Feb 7, 2008 | 04:59 PM
Brads RS's Avatar
sounds to me you have an ignition switch linkage problem not a wiring problem. Check the adjustment on the ignition switch, and i'm not talking about the lock cylinder (there is a difference). You'll most probablly find that the switch is misadjusted or bad.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
