adding a coolant temp gauge (aftermarket)
Old Dec 7, 2007 | 12:22 AM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
I changed my 305 4bbl to a 350 TPI. Everything works great. Passed emissions. Now the final things to do. Reconnect the oil pressure gauge and coolant temp gauge. I wouldn't mind hooking up the original but I have aftermarket gauges just in case. If someone can let me know where I can hook up the original connectors to the tpi motor, I would greatly appreciate it.
Old Dec 7, 2007 | 02:18 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: adding a coolant temp gauge (aftermarket)
I'm sure someone can correct me if I'm wrong, but there should be a port right above the oil filter (on the block) for the oil pressure sender. And there ports for water temp are on the sides of the block, below the headers/manifolds.. I'm not 100% sure between what cylinders, though... If you do a search, you'll get exact answers...
Old Dec 11, 2007 | 02:42 PM
rodie_27's Avatar
Car: '89 IROC convertible
Engine: 355 TPI
Axle/Gears: 3.45? Posi
On my '89 with a Tuned Port 305, the coolant temp sensor for the gauge is between 1 and 3 cylinder (driver's side between the front 2 cylinders) like HCR13 said.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
roysatikas
Sep 7, 2015 08:08 PM
85Special
Sep 3, 2015 04:21 PM
