Help with fuses.
Old Dec 7, 2007 | 04:35 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Power Locks, Cigarette lighter, and Hatch release not working
Does anybody know what specific fuse controls the Cigarette lighter, power locks and the hatch release? Ive looked at a diagram and cant figure out which one to replace. All of those things stopped working on my way into work tonight and id like to just walk out and pop a fuse in without pulling out each one to figure out which one blew.
Cars is a 91 RS.
Old Dec 7, 2007 | 06:10 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Help with fuses.
I belive it is the pwr acc fuse, 30 amp fuse.
Old Dec 7, 2007 | 08:31 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
It is the ACC fuse.
You'll most likely need more than one. Chances are your replacement will also blow, then you'll need to figure out which circuit is shorted out. The most common culprit is the cigarette lighter and/or its wiring. For me, it was the underhood light, just unplugged it and let it be - might check that too if you have one. BTW your horn is also on that fuse
Old Dec 8, 2007 | 03:20 PM
Saber's Avatar
Replaced the fuse today and my hatch motor release switch, locks, and cigarette lighter dont work still. Assuming the damn cigarette lighter is bad what would i do to fix it? The problem actually started when i plugged in my phone charger.
Old Dec 8, 2007 | 04:14 PM
Saber's Avatar
Well the replacement fuse has not blown yet and all three still do not work..... I really suck at fixing electrical problems so any help is greatly appreciated.
Old Dec 8, 2007 | 08:02 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Are you sure you replaced the right one? There are 2 ACC fuses under there.
If it worked before you plugged in your phone charger it should just be a matter of changing the fuse out. My 89 is the same way with the ciggarette lighter, if I plug anything into it it will blow the fuse everytime. Here is a link to autozone's wiring diagrams, it is for firebirds but it is the same for camaros
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Just scroll down to 91 body wiring cont. and it shows which fuses go where.
thunderstick
Aug 20, 2005 05:51 AM
coolguywalt
Aug 14, 2005 10:03 PM
verc
Oct 7, 2004 07:25 PM
