NONE OF MY INTIRIOR LIGHTS WORK ALL FUSES ARE GOOD PLEASE HELP..
Old Dec 19, 2007 | 08:28 PM
02 camaro's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
I HAVE A 1989 FIREBIRD formula. Everything works but the power pull down hatch and all the interior lights. I checked all the fuses and all of them are good. So what could it be?...Also when i press the trunk button on the dash it does not click like all other firebird that i have seen. So could you please help me. Like i said all the fuses are good and all the bulbs are good.
Also what is the little thing that says "Gain" and has a little music button next to it?..Thanks
Old Dec 19, 2007 | 09:54 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: NONE OF MY INTIRIOR LIGHTS WORK ALL FUSES ARE GOOD PLEASE HELP..
test light the spade fuse sockets for power, one will be hot and the other wont be, for the courtesy lights, if not then something is wrong in the wiring somewhere
if the dash lights and instrument panel guages lights dont woirk either then it is probably the headlamp switch bad
check that fuse for power also, with the headlamp switch on and with the dimmer dial turned up
Old Dec 20, 2007 | 09:42 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The switch is for a factory installed Subwoofer sound system. There should be an extra Amp behind the dash housing and the rear speakers should be enclosed in special boxes made just for that set-up. Each rear speaker box contains 2 speakers rather than 1 like in most ThirdGens.
Old Dec 20, 2007 | 10:10 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I have included wiring diagrams for your car. I hope these help
File Type: pdf
File Type: pdf
Old Dec 20, 2007 | 02:01 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
Sweet...lol...to bad it doesent work How can i check to see if the amp is still there
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
