headlights
Old Jan 1, 2008 | 10:06 AM
paulisgod's Avatar
Car: GM
Engine: v8
Transmission: slushboxes
headlights
my lights on my bird don't work when in low beam. The passenger one is out. When you turn on the brights, both lights go on. When you go back to low beam, it does switch to low beams but the passenger one turns off. WTF? I did both headlight motors last year but didn't have problems till yesterday. What gives?
Old Jan 1, 2008 | 10:41 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: headlights
replace headlight on the passenger side with the driver side to see if it's the bulb. Otherwise there is an issue with the socket that plugs into the headlight, or the wires going to the headlight from the driverside of the car.
Old Jan 1, 2008 | 03:27 PM
paulisgod's Avatar
Car: GM
Engine: v8
Re: headlights
new silver stars work with brights on both sides. What about the sockets? What do I check? Is there anything else it could be?
Old Jan 1, 2008 | 03:35 PM
84redta's Avatar
Re: headlights
the sockets could be melted/corroded, otherwise it's the wiring between the high/low beam switch in the column and the actual headlight, or it's the high/low beam switch itself...check all wires and pray it's not the switch cause then you gotta tear the column apart to get to it. If you happen to have any friends with firebirds, you may want to see if they will let you test your headlight switch with thiers if theirs work, but i don't think it's that.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
